1997 Chevy Truck Shifter Cable
JOHNWAYNE
Transmission problem
1997 Chevy Truck V8 Two Wheel Drive Automatic
How to remove and install auto shifter cable at tranamission
Jul 12, 2008 at 12:22 AM
2CARPRO JACK
  • 11,533 POSTS
Just at the trans? you have to pry the end off the trans lever with aflat blade screwdriver.Then there is a 2 prong reataining clip you remove where the cable goes through the bracket. Then squeeze the sides that stick out together and pull the cable back through the bracket
Jul 12, 2008 at 1:30 AM
