1997 Chevy Truck Replaced water pump now leaking coolant
70,000 MILES • 4 CYL • 2WD • MANUAL
SHANGTANG
I replaced my water pump yesterday and today driving it I noticed a large amount of coolant was leaking from the bottom of the truck.
Does this mean the water pump is not fitted correctly?
Also the steering locked up as soon as I was pulling into the drive way with a little bit of steam coming out of the hood. I wonder if this has something to do with the belt when I put it back on?
May 10, 2010 at 3:38 PM
  • 31,937 POSTS
Hi there,
The first thing to do is to get the coolant leak identified, best to go get a cooling system pressure test, this may well be related to the water pump replacement, check this first.
mark (mhpautos)
May 10, 2010 at 8:01 PM
