1997 Chevy Truck removing rotor
106,000 MILES • V8 • 2WD • AUTOMATIC
DRAGOCHEVY
how do i remove the front rotor on a 97 chevy 1500 2wd truck
Dec 26, 2007 at 10:00 AM
BLACKOP555
  • 10,386 POSTS
take off the tire, then the wheel hub nut located in the center, take off the caliper and pull off the rotor.
Dec 26, 2007 at 1:45 PM
DRAGOCHEVY
do you know the size socket i need to get off the nut?
Dec 27, 2007 at 10:55 AM
BLACKOP555
  • 10,386 POSTS
not off the top of my head, normally it wont be too tight and you could loosen it by hand or a pair of pliers. usually the nut is near 15/16ths
Dec 27, 2007 at 12:49 PM
