1997 Chevy Truck Oil Pan Removal
307,000 MILES • 6 CYL • 2WD • AUTOMATIC
WDTJR88
Do I need to take out the three bolts where the bell housing meets the oil pan for removal? Do I need to remove the two bolts behind the rubber bell housing plugs to remove the oil pan?
Jan 2, 2010 at 8:47 AM
  • 110,248 POSTS
The actuall oil pan doesn't bolt to the transmission in any location. There will be a inspection plate to remove and the starter needs removed.
Jan 2, 2010 at 12:50 PM
