oil pressure gauge and whats the normal pressure
118,000 MILES • 6 CYL • 4WD • AUTOMATIC
SHAKKEY13
  • 8 POSTS
i have a oil pressure gauge and whats the normal pressure rate for this LS 4.3L V6 vortec my oil pressure jumps from 40LBS at Idle to Close to 60lbs when driving i hade the Oil sending unit replaced in November should i be worried about blowing of my Oil Filter
Dec 31, 2009 at 10:27 AM
BLUELIGHTNIN6
  • 16,542 POSTS
what is this on exactly??
A '97 S-10 V6 vortec is only 6psi at 1k RPM and 24psi at 4k RPM. This is for the s10..there are several LS models for Chevy though...Venture LS, Monte Carlo LS etc....
Apr 21, 2021 at 4:52 AM
SHAKKEY13
  • 8 POSTS
My truck is The 1997 C/K 1500 W/T 4wd chevy full size pickup truck single cab 8 ft box
BLUELIGHTNIN6
  • 16,542 POSTS
your oil pressure specs remain the same..
https://images.2carpros.com/forum/automotive_pictures/261618_Noname_1390.jpg
