1997 Chevy Truck Kelsey-Hayes Trailer Brake Control
197,000 MILES • V8 • 2WD • AUTOMATIC
CCLARK55
I have the pickup described and am trying to set up trailer brakes. I bought it used and the seller didn't know much about it. I want to put a trailer brake control on it, but can't find the socket to plug in the wire harness under the dash. The more I look, the more I think there was a factor trailer brake hook up installed. There is a Kelsey-Hayes box in front of the master cylinder and there is a red and blue wire (about 12ga) taped up to the trailer light harness. When I hook a voltmeter up to the red wire and ground and step on the brake I get a minimal voltage. My reading up on K-H brake controllers tells me that the controller is inertial-proportional so it has to be in motion to apply voltage. Is there a way I can sort this out? I'd love to take the brake controller back to the parts store. Suggestions???
Thanks
Clay
Jul 24, 2010 at 8:10 AM
  • 75,988 POSTS
Hi cclark55, Welcome to 2carpros and TY for the donation
Can't promise you I can get this right, due to manufactures of controllers
This controller does it have 4 wires, blue, white, red and black. Answer this before hook-up If so the Blue is power to the trailer brakes, white is chassis ground, red is to the brake switch, black is fused to bat +. let me know
Jul 25, 2010 at 6:42 PM
