1997 Chevy Truck hIGH iDLE
1997 CHEVROLET TRUCK
117,984 MILES • 6 CYL • 4WD • AUTOMATIC
SHAKKEY13
  • 8 POSTS
In the summer my truck's idle would start at 1000RPM on start up and would settle after 5 min at 600 rpm
Now winter has come its always -3 Celcius out and now its starts a 1000RPM and wont settle at 600 rpm now it sits a 1000-900 but will settle when engaged into ODrive goes to normal 600 rpm new EGR valve last summer
Dec 10, 2009 at 4:45 AM
BLACKOP555
  • 10,386 POSTS
take out the idle air control motor. its gonna have to idle a bit higher for longer due to the temperature now.
clean up the iac when you get it out. also start checking for vaccum leaks. use a can of carbuerator cleaner.
Dec 10, 2009 at 8:26 AM
SHAKKEY13
  • 8 POSTS
This actually turned out too be a faulty O2 post cat sensor this was the tell tale sign before the engine light came on in the dash stating the error code in emissions control module
Dec 6, 2010 at 12:33 PM
