1997 Chevy Truck Hard starting
MIKE YOST
  • 1997 CHEVROLET TRUCK
Electrical problem
1997 Chevy Truck Two Wheel Drive Automatic 109697 miles
We have had this truck for several years I has a V-6 gas engine. It has progressively become harder to start. It sounds like it is out of time. The starter labors to turn the engine over. I had the starter repaired with a new armature as it was burt in many areas. When I installed the starter again the same problem existed. I has gotten to the point that it will rarely start and when it does the idle speed increases and decreases like a gallop. I can only assume it is an electrical component but am not sure where to start.
Friday, January 2nd, 2009 AT 7:16 PM
  • 109,885 POSTS
Hi:
If the starter still has to work really hard, are you sure the battery is good? Also, the idle you described could be caused by low voltage, a bad IAC or TPS. Have you had the computer scanned for codes? That is where I would start with the idle, and the battery is where I would start with the hard start.
Let me know what you find.
Thursday, January 8th, 2009 AT 4:23 PM
