1997 Chevy Truck fuel pump replacement
200,000 MILES • V8 • 4WD • AUTOMATIC
TEAKS
I'm pretty sure my fuel pump is dying. How can I tell if i can just replace the pump or i have to replace the sender and everything?
Aug 20, 2009 at 12:19 AM
DR LOOT
  • 2,311 POSTS
the fuel pump and the sender are together in the same unit, you do not need to replace the sender only the pump.
Aug 20, 2009 at 4:39 PM
