1997 Chevy Truck Fuel pump
TODD LUCAS
  • 1997 CHEVROLET TRUCK
  • V8
  • 4WD
  • 166,000 MILES
Does fuel pump suppose to kick in every time you turn on key, and if so what would cause it not too?
Monday, August 16th, 2010 AT 3:21 PM
JDL
  • 16,098 POSTS
Yes, it should kick on everytime you cycle the key. Possibilities, faulty relay, pump issue, wiring issue, pcm. Engine cranking, use a gage and check fuel pressure. I wouldn't replace anything without being sure what we're dealing with. There are other issues that might cause that.
Monday, August 16th, 2010 AT 3:43 PM
