1997 Chevy Truck FUEL
40,000 MILES • V8 • 2WD • AUTOMATIC
CREWDAWG692
ENGINE WILL RUN ON STARTING FLUID OR CARB CLEANER. HAVE GOOD FUEL PRESSURE 62PSI AND SPARK TOOK THROTTLE BODY OFF CLEANED BUT WILL NOT RUN SEEMS LIKE NOT GETTING FUEL TO THROTTLE BODY. WHERE IS THE LOCATION OF THE FUEL PRESSURE REGULATOR. IT IS A 1997 P-30 CHEVROLET STEP VAN.
Jun 23, 2009 at 11:05 PM
  • 75,988 POSTS
Check the injectors if its pulsing
Jun 23, 2009 at 11:20 PM
JOEJOE383
  • 16 POSTS
idk about the vans but if its got the vortec engine the fuel pressure regulator is under the upper intake
Jun 29, 2009 at 5:17 PM
  • 75,988 POSTS
CPI has the pressure regulator underneath the upper plenum. TBI its contain within the unit
Jun 29, 2009 at 5:22 PM
