1997 Chevy Truck Engine misfiring
JLM405
  • 1997 CHEVROLET TRUCK
  • V8
  • 4WD
  • 270,000 MILES
My 1997 chevy p/u k1500 with over 270000 miles started losing power and misfiring to the point where the truck was having trouble going up hills. The usual suspects were replaced ( cap, rotor, plugs, and wires) but the truck continues to misfire. Need expert advise.
Friday, June 25th, 2010 AT 4:05 PM
Possibilities: Inspect and test all the following listed below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Crankshaft position sensor
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard
Friday, June 25th, 2010 AT 4:06 PM
