1997 Chevy Truck brake lights
206,000 MILES • V8 • 4WD • AUTOMATIC
ISMAEL75
my brake lights flicker when i hit the pedal and I think it's the brake switch. I'm not sure but I was wondering what our opinion was and if so how do I replace it??
Jul 18, 2008 at 1:26 PM
DAD1950PU
It is a little hard to change it is in a very tight spot. It will rool out of a clip you can unplug it from the wire harness and plug the new one on. I have had to chage out two the replacement swiches are a litttle week in how they are made. They can pop apart partialy and stop working . I fixed this by wrapping it in electrical tape so that it can not seperate. This switch controls brake lights annd cruise control if you have it. It will give you a service engine light if it fails and the cruise control stops working.
Aug 28, 2008 at 4:18 AM
