1997 Chevy Truck backfiring at driving speed
1997 CHEVROLET TRUCK
172,000 MILES • V8 • 4WD • MANUAL
CARP 76
engine runs extremly rough while holding any speed. i have replaced plugs and wires, coil pack, fuel filter, and cleaned egr. still the same so i replaced the egr with a used one from junk yard. seems to run better when air temp. is cold warmer temp the rougher it will run. sure could use some help.
Feb 13, 2008 at 9:10 AM
MASTERTECHTIM
  • 4,750 POSTS
sounds like a cpi problem or you still have carbon holding open the egr. does it have any codes? do you know the fuel pressure? is the timing changing?
Feb 13, 2008 at 9:14 AM
