1997 Chevy Truck 97 Chevy 1500 P0442 & will not acceler
1997 CHEVROLET TRUCK
LCMEDINA88
Engine Performance problem
1997 Chevy Truck 6 cyl Automatic
I have taken my pickup (97 Chevy pickup 1500) no one can seem to find out what is wrong with my truck. I was coming home from out of town(295 miles away)I had it on cruise control. I came upon a steep hill & my truck would not continue to accelerate. I took it off the cruise control & tried to press on the gas but nothing it would not go any faster than 20miles per hour. I made it to the next town. I let my pickup cool down then it would start but if I press down on the accelerator it would die. If I turned it on & let it go at its speed (10miles per hour)without pressing on the accelerator it did fine. The 'check engine soon' light had been on so I decided to take it to Auto Zone to check for a code P0442(evaporative emission system)small leak/no flow condition. I took it to a shop to get it checked on they put on a new catalytic converter??. It didn't solve the problem. They told me it was the fuel pump. I had the fuel pump changed.
Two months ago I took the same trip(295 miles away) the accelerating problem has not happened again but the 'check engine soon' light with the exact same code P0442 came on again when it would not accelerate. My concern is I live in Texas so there is a long distance between towns where I travel to & from so if my pickup acts up again I may be left stranded out there waiting. No one has been able to figure out what is going on. My brother is a mechanic he has check it: replaced fuel cap,checked the hoses for cracks & checked the pressure but nothing. What could be going on with my pickup? Please help..
Jun 24, 2009 at 4:24 AM
A code P0442 most likely means one or more of the following has happened:
A loose or improperly affixed gas cap
A non-conforming gas cap (i.e. not factory/original brand)
A small leak/hole in a fuel vapor hose/tube
Other small leak in EVAP system
Faulty vent o-ring seal
Possible SolutionsWith a P0442, the most common repair is to:
Remove and reinstall the gas cap, clear the codes, and drive for a day and see if the codes come back.
Otherwise, replace the gas cap, or
Inspect the EVAP system for cuts/holes in tubes/hoses
Also check the throttle positon and MAP sensors
Jun 24, 2009 at 4:30 AM
