1997 Chevy Truck 4 WHEEL WILL NOT ENGAGE
210,000 MILES • V8 • 4WD • AUTOMATIC
NRITACCO
When I press the 4Hi button, the light just blinks and the transfer case never goes into 4 wheel drive. I've been under the truck while the button was being pushed, and I could hear the solenoid motor responding. I put a meter on the 2 wire connector, and got ~12v when the 4Hi button was pushed. Any suggestions?
Thank you,
Nick
Dec 7, 2009 at 4:09 AM
  • 110,248 POSTS
Nick:
Chances are the actuator is bad. If you are getting 12v to it, it should be working. Remove the actuator and check to see if it responds when it is removed from the transfercase.
Let me know what you find.
Dec 12, 2009 at 6:08 AM
NRITACCO
Jacobandnickolas,
Thank you for your response. I actually ended up bringing it into the dealer and they replaced the transfer switch (a $44 part). All is well with the 4 wheel drive again.
Thanks again,
Nick
Dec 13, 2009 at 6:08 AM
