1997 Chevy Truck
133,033 MILES • V8 • 4WD • AUTOMATIC
JACK BATEY
MY TRUCK IS SLOWLY BUT SHURLEY LOOSEING POWER,AT FIRST IT WOULD DIE WHILE DRIVE ING,SO I CHANGED THE FUEL PUMP RELAY CUBE,THAT WORKED FOR A LITTLE WHILE,NOW IT IS GETTING HARD TO START,I CAN TURN ON THE KEY AND SIT FOR A LITTLE WHILE AND THEN IT WILL CRANK,SOMETIMES I CAN SWAP THE RELAY CUBES AROUND AND IT WILL CRANK,IT SEEMS TO BE LOOSEING MORE PULLING POWER EVERY TIME I DRIVE IT,I HAD A NEW ENGINE INSTALLED A FEW MONTHS AGO,IT HAS NOT FELT RIGHT SENCE,WHAT DO YOU THINK?
Aug 11, 2009 at 2:24 AM
  • 110,248 POSTS
Have you checked to make sure the catylatic converter isn't plugging?
Aug 17, 2009 at 4:56 PM
