1996 Tahoe won't stop quickly
SGALAT
I am the original owner of a 1996 Chevy Tahoe with 137,000 miles on it. My concern is that the vehicle cannot brake quickly. I can come to a normal stop but to brake quickly - in the case of preventing an accident the vehicle doesn't seem to be able to stop. I cannot lock the tires up at all. I recently have had an accident because I was not able to stop in time.
The rotors and pads have been replaced numerous times but my ability to quickly stop has not been an option. I recently purchased a 23ft boat and plan on towing it with this vehicle. I'm concerned about my ability to stop when adding additional weight to the vehicle.
I would appreciate any thoughts. Thank you.
Feb 24, 2007 at 1:15 AM
SERVICE WRITER
  • 9,123 POSTS
I think there is a recall on an abs problem with that truck, check with the dealer, have your vin number handy.
Feb 25, 2007 at 3:54 AM
SGALAT
Paul, Thanks for the thought. I called and unfortunatly no recalls. Any other suggestions or ideas out there?
Mar 2, 2007 at 2:30 AM
SERVICE WRITER
  • 9,123 POSTS
The next 2 things I would check are the brake rotor surface quality of both front and rears, inside and outside.
if there is pitting or reduced contact that will affect it.
Next I would want to see if the bcm has stored any codes related to abs.
Mar 2, 2007 at 7:51 AM
