Where is the brown wire located to diconnect the est to use timing light? Is not around the distributor or fire wall or behind glove box.
Dec 4, 2009 at 7:38 AM
42DEGREES
MEMBER
On a 96 there is no wire for this. Timing is controlled exclusively by the PCM. The distributor is installed with #1 cylinder at TDC and the rotor pointing to the tab on the distributor base marked with an "8". Fine adjustment (if needed) must be done using a scan tool. If the distributor is installed incorrectly the vehicle will set a DTC of P1345
42°
Dec 9, 2009 at 4:03 AM
