1996 Chevy Truck Throttle Position Sensor
97,000 MILES • V8 • 2WD • AUTOMATIC
POPOJOHN
Check engine light came on, and it was coded - showed that the throttle position sensor was bad. Had it replaced and a couple of hours later the light came back on. Once again the code showed that the throttle sensor was bad - had it replaced for the second time. Two days later, the light is back on and the code shows that the throttle sensor is bad, again. Occasionally, the check engine light will go off, and the pickup runs great - then the light comes back on.
Oct 18, 2010 at 1:47 PM
  • 75,988 POSTS
Replaced 2X and still don't work-try adjusting the closed/wide open throttle voltages, and check the wiring back to the computer if okay-think! computer
Oct 18, 2010 at 2:34 PM
