1996 Chevy Truck Setting the distributor.
DRAG0N
Engine Mechanical problem
1996 Chevy Truck V8 Two Wheel Drive Automatic
I had my enigine completely overhauled,bored and all new internals installed. So I was givin back a fresh long block from the machine shop. Got everything together and in the truck, Now I just can't seem to get the Distributor set correctly. I know to bring number one to TDC and the rotor is to be pointing at the little 8 on the dist. base. But i'm getting nothing but popping and coughing when i try to start the truck. Thought maybe I was 180 off ,but I get the same thing. no matter what...Anyone got a fresh Idea. cause I'm out of them..??
Feb 17, 2009 at 5:51 AM
  • 75,988 POSTS
When the distributor is properly installed the rotor should be pointing to the no.1 cap tower
Feb 17, 2009 at 7:26 AM
DRAG0N
I got the problem resolved, Just did not know that the vortec's were so touchy on the timing.. Thank you.
Feb 19, 2009 at 5:02 AM
