1996 Chevy Truck oil leaking from under truck
ANNA JOHNSON
Engine Performance problem
1996 Chevy Truck 6 cyl Front Wheel Drive 100000 miles
engine light came on and goes off after vehichle is running on highway, also when truck is setting it leaks a greenest,blue liquid. a small amount. what could be wrong . just had a new radiator put in.
Jun 17, 2010 at 6:30 AM
DR LOOT
  • 2,311 POSTS
The first thing I would do is replace the oil sending unit it is located on the drivers side at the back of the engine, and the "greenest,blue liquid" is most likely the radiator leaking again, you better take it back to whoever repaired it.
Jun 18, 2010 at 1:29 PM
