My truck was difficult to start the last few times, but once it starts, its fine. This morning, I sprayed some starter fluid in the carb,(first time to try that) and it fired right up. I had to stop for a few minutes, and it would not start. I sprayed starter spray and it would start, then die. I thought it was a fuel feed problem. Changed the inline filter, still would not start. I changed the mass airflow sensor (expensive booger) on the air filter line. Still trouble starting without starter fluid. But this time it would not die, it idled ok. I drove it back home, turned it off, and restarted it fine. Waited 10 min, and it wouldn't start. The service engine light is on. Currently, there is no way to get it to an auto zone to put it on the computer. Any help would be appreciated.
Jul 7, 2009 at 9:11 AM
