1996 Chevy Truck Hesitation
YAMADUDER
  • 1996 CHEVROLET TRUCK
  • V8
  • 134,000 MILES
My truck hesitates very bad when the engine is first started but it seems to clear up after the first couple blocks. Also once it is warm it seems to surge on acceleration and after being driven hard it will usually lose most power to the point that it has to be in second gear to maintain 60mph and the truck seems to shake. This problem can usually be eliminated by shutting it down for thirty seconds and restarting it. The truck seems to run better at full throttle but still doesn't have the power that it should. When it is cold at half throttle it makes a loud clunking noise. It has new plugs new fuel filter new fuel pump new front oxygen sensors and removed catalytic converters. It is not sending any codes so a code scanner can't help in determining the problem.
Friday, September 19th, 2008 AT 3:55 PM
Possible Causes of Engine Hesitation
Dirty fuel injectors (cleaning the injectors often fixes this).
Bad MAP (manifold absolute pressure) sensor
Bad TPS (throttle position) sensor
Bad or dirty MAF (mass airflow) sensor
Low fuel pressure (leaky fuel pressure regulator or weak fuel pump)
Vacuum leaks (intake manifold, vacuum hoses, throttle body, EGR valve)
Bad gasoline (fuel contaminated with water or too much alcohol)
Sometimes, what feels like a hesitation is actually ignition misfire rather than lean misfire. The causes of ignition misfire may include:
Dirty or worn spark plugs
Bad plug wires
Weak ignition coil
Wet plug wires
Friday, September 19th, 2008 AT 7:11 PM
