1996 Chevy Truck headlight running lights
180,000 MILES • V8 • 4WD • AUTOMATIC
BOBXL1200
I checked the fuse for the running light s I also replaced dlr relay they still don't work could the headlight bulbs be buirnt out I bought the truck in 1998 and have never replaced a headlight bulb thank you
Oct 26, 2009 at 6:52 AM
IMPALASS
  • 3,112 POSTS
Hello –
I would check the bulbs first……..yes………it may just be the bulb……..you could check voltage at the plug………….
If it were me – I would just purchase the bulb and test………you can also look at the bulb to possible see if the filament is broken.
Oct 26, 2009 at 2:56 PM
