1996 Chevy Truck fuel pump
T3582
  • 1996 CHEVROLET TRUCK
Engine Performance problem
1996 Chevy Truck 4 cyl Two Wheel Drive Automatic
Replaced fuel pump, now truck won't start.
Saturday, October 30th, 2010 AT 5:06 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Make sure fuel pump is getting power, did engine start prior to pump replacement?
Saturday, October 30th, 2010 AT 8:21 PM
T3582
  • 5 POSTS
Yes, truck was running prior to installing new fuel pump
Saturday, October 30th, 2010 AT 10:14 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Is pump getting power?
Saturday, October 30th, 2010 AT 10:15 PM
T3582
  • 5 POSTS
Yes there is power. Gas goes through pump, but not getting to carburetor.
Sunday, October 31st, 2010 AT 3:56 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Make sure fuel filter is not clogged, can remove and try blowing through it to test.
Sunday, October 31st, 2010 AT 4:01 PM
T3582
  • 5 POSTS
Put new fuel filter. Have gas to the input manifold.
Sunday, October 31st, 2010 AT 4:32 PM
BLUELIGHTNIN6
  • 16,542 POSTS
What pressure is the pump putting out? If fuel is getting to intake but not carb then either carb is bad/clogged or fuel pressure is weak.
Sunday, October 31st, 2010 AT 6:28 PM
T3582
  • 5 POSTS
OK Thanks. Will check carburator
Sunday, October 31st, 2010 AT 7:44 PM
