Fuel pressure regulator vacuum line
150,000 MILES • 6 CYL • 2WD • AUTOMATIC
1ACE1
i have the truck listed above, 4.3l v-6. Where does the vacuum line from fuel regulator run to?
May 25, 2009 at 5:44 AM
This regulator just uses manifold vacuum. So basically, it is going to have a line running to the manifold which is most likely going to have a multiport connector for the vacuum. This means there will not be a nipple on the manifold for every connection that requires vacuum. There will be a splitter that will allow each to have manifold vacuum to each of them.
Here is a guide that helps with checking pressure which is a good idea any time you have fuel pressure issues:
Please see the info below and let me know what questions you have.
Thanks
May 7, 2022 at 11:18 AM
