GOZZ66
Engine Performance problem V8 Four Wheel Drive Automatic 246000 miles
I WAS DRIVING IT AND IT JUST QUIT AND WOULD NOT RESTART. I CAN HEAR THE FUEL PUMP COMING ON FOR THAT INITIAL 2 SECS EVERY TIME A CYCLED THE KEY. I THOUGHT I WAS NOT GETTING SPARK UNTIL I STARTED THE ENGINE ON STARTING FLUID. SO I GUESS IT IS A FUEL PROBLEM AFTER ALL? I HAVE FUEL @ THE RAIL. SO IF I HAVE SPARK AND FUEL, WHAT ELSE COULD IT BE?? I CHECKED ALL OF MY FUSES AND THEY ARE ALL OK?? MY FUEL PRESSURE REG I THINK IS OK. I PULLED MY OIL DIP STICK AND THERE WAS NO FUEL INSIDE OF MY CRANK CASE. I DON'T SMELL ANY FUEL AT ALL WHEN CRANKING THE ENGINE.. I ALSO HAVE POWER AT MY IN HARNESS. PLEASE HELP...
Nov 23, 2009 at 8:43 AM
JDL
  • 16,098 POSTS
Welcome to the forum, use a gauge and check fuel pressure, 60 psi or better, key on engine off. Also, the fuel poppets on the spider system may need to be cleaned.
Nov 24, 2009 at 12:59 AM
