1996 Chevy Truck brakes
1996 CHEVROLET TRUCK
70,500 MILES • V8 • 2WD • AUTOMATIC
KEN2BE
Brakes will not bleed right Brake pepple going to floor not holding good. ken
Dec 9, 2007 at 11:14 AM
  • 31,937 POSTS
Hi there,
If you have been bleeding the brakes correctly and still not getting a good peal, you may have a faulty master cylinder. Sometimes the internal seal of the master cylinder will by-pass fluid causing the pedal to drop. ensure that you are bleeding correctly, if there is any sign of fluid leaking from the rear of the cylinder over haul or replace. A trained brake technician will have to inspect the master cyl to confirm if it is by-passing.
Mark (mhpautos)
Dec 9, 2007 at 7:34 PM
