1996 Chevy Truck a/c
BAMA BRIAN
Air Conditioning problem
1996 Chevy Truck Two Wheel Drive Automatic
brand new clutch motor,heater works, temperature gets hot,but the a/c or the heater wont blow through the vents,you can feel the heat and air blowing by the floor but it wont come through the vents.any info i can use. appreciated
Jan 24, 2008 at 6:03 PM
BILLYBOBASAN
  • 13 POSTS
Hi, I believe this model trk has electrical motors to control air flow & temp. The mode actuator is located on left side of HVAC box above gas pedal to the right. It has a small connector with 3 or 4 wires going into it & three screws holding it on. Sometimes wiggleing the wires will get it to working but you will probably have to replace it with a new one.
Hope this helps,
Billybob
Feb 1, 2008 at 1:52 AM
