1996 4.3l chevy Possible ground issue or Computer problem?
1996 CHEVROLET TRUCK
PWATSON
I installed a 1999 chevy 4.3L engine with a 1996 chevy manuel computer in my 1947 Willy's project. I have borrowed a OBD II scan tool which was working while I was trying to figure out why my engine was running rough and very rich, I replaced the plug wires, the plugs, the front O2 sensors and the fuel pressure regulator chasing the problem. The engine is still running very rough rich smell of gas and some small back firing. The scan tool won't read now either, so I found that I had not grounded the wiring harness and the block so I did that, it still is not comunicating, the scan tool either says waiting for information or when you go to engine controls the scan tool says the engine controls are timed out. Is it possible I did something to the computer by not having it grounded properly? Or maybe I don't have it grounded right yet? I grounded from the body to the frame and from the same point on the body to the block and from the same point on the block to the same point on the frame and then from the same point on the frame to the neg terminal on the battery, I attached the ground wire coming out of my wiring harness to the same spot on the firewall I grounded to the frame. The wiring harness is a custom harness for these type of applications. Thanks for your help in advance.
Jan 13, 2007 at 8:07 AM
SERVICE WRITER
  • 9,123 POSTS
I don't know how much I can help, but through our dialog someone else may jump in.
Normally I would stay away from a franklenstein of a sort, but a donator will always get preference from me.
Try the scan tool on another car to see if it's okay.
We can go from there.
what vehicle was that computer out of?
Jan 13, 2007 at 10:35 AM
PWATSON
the computer is out of a S-10 Manuel trans 1996, The scan tool was working and it is still working with regards to putting in what yr model and engine, you can select engine controls, sensor data etc. when you select sensor data it flashes waiting for data. When I go to engine controls and say I select reset IAC it comes back with a message engine controls timed out check connections.
Jan 13, 2007 at 10:51 AM
SERVICE WRITER
  • 9,123 POSTS
I really wish I could help but is clearly out of my area. Hopefully someone else can jump in on this. I wish you luck on your project.
Jan 13, 2007 at 11:32 AM
