1995 Chevy Truck tuneup question
12,000 MILES • V8 • 2WD • MANUAL
MIKE DUNCAN
motor hesitates under low RPM load. Example: If I shift into 3rd at 20 MPH the motor hesiates when i try to accelerate. Once the speed picks up it runs smooth. Example: When driving at 70MPH with the cruize on and I start up a hill the engine hesiitates under the addded load, once I reach the top of the hill I can accelerate without motor heisitation. As long as the RMP'S stay high the acceleration is good, without heitation but when the motor has a load at low RPM it misses.
Jan 11, 2010 at 1:11 AM
DOCFIXIT
  • 18,828 POSTS
Could be several things plug, plug wire, coil, dirty fuel injector,low fuel pressure. Check engine light comming on?
Jan 11, 2010 at 1:33 AM
MIKE DUNCAN
is there a way to identify the problem rather than replacing parts that might not need replacing. I'd like to narrow down the possibilities. The check engine like is not on
Jan 11, 2010 at 2:11 AM
