1995 Chevy Truck to gstacey
JDESHON
  • 1995 CHEVROLET TRUCK
  • V8
  • 4WD
  • MANUAL
  • 167,000 MILES
Re: deshon '95 chevy 1500 high idle problems
hope this gets to you, gstacey. No codes are showing up, no check engine light on. How would you get a code to come up if no check engine light is on? Will be trying your advise. Hope it does the trick
jdeshon@ptd. Net
Saturday, February 6th, 2010 AT 9:08 PM
FACTORYJACK
  • 4,159 POSTS
It could very likely have no codes. The check engine light does work when key is turned on, correct? If you jump terminals A and B at the diagnostic connector, it should at least flash a code 12, which indicates diagnostic mode is entered.
Sunday, February 7th, 2010 AT 12:09 PM
