Don't do the answer initially provided to your question.
I have the same problem.
It won't work and you could damage the van.
The 1995 Lumina Van doesn't use the OBD scanner tools either 1 or 2.
Don't try to do the jump think either.
The scanner connector isn't wired that way.
OBD 1 causes the flashing light thing. 12 pin connector.
OBD 2 reads codes. 16 pin connector.
The 1995 Lumina Van (right out of the shop manual) uses a "Tech 1 Scan Tool" to read codes.
(12 pin connector OBD 1 will fit but not work)
Auto Zone isn't fluent with it, neither is Advanced Auto.
Ebay only has scant reference at a cost of several hundreds bucks.
SPONSORED LINKS
Saturday, February 3rd, 2007 AT 8:06 PM
