1995 Chevy Truck short
204,000 MILES • V8 • 4WD • MANUAL
LAZYVINRULZ
how do i find a short? found a 50 amp fuse blown under the hood.when replacing fuse it arc and blown fuse again. fuse is for ac.
Oct 12, 2009 at 2:53 AM
JDL
  • 16,098 POSTS
That fuse circuit only goes hot with the key on, according to my info? With the hvac controls turned off and the key off, the fuse still blows??
If the fuse doesn't blow till you turn on the key, unplug the blower relay, then with the key on, hvac controls off, use a testlite across fuse terminals, if the lite comes on, there is probably short on the wiring circuit going to the relay. Instead of hunting the short, I'd probably just replace the wire.
Oct 12, 2009 at 3:26 AM
