1995 Chevy Truck rough running,try to die at acceleration
135,000 MILES • 6 CYL • 2WD • MANUAL
GDUDE1968
she will run good for 5 minutes then die on acceleration,bucking hesitating if i put it to the floor she takes off and goes.i replaced fuel filter rotor spark plugs and wires.
Feb 14, 2008 at 10:07 AM
  • 75,988 POSTS
Do you have a check engine light On or has flashed
Try checking the throttle position sensor/MAP&MAF sensor and actual fuel pressure
Feb 14, 2008 at 3:37 PM
