where is the location of the iac valve on a 95 chevy pick-up
Jan 19, 2008 at 8:15 AM
MASTERTECHTIM
✓Experienced Mechanic
it is located on the throttle body. have somebody press on gas with engine off, you will see the cables going to the throttle body. the iac valve has 4 wires going to it and is held in by 2 torx screws. they do not go bad often, may i ask what your problem is.
Jan 19, 2008 at 8:24 AM
CLAY001
MEMBER
1 POST
i replaced the motor recently i am now having issues with truck idling(it wont) and stalling out when coming to a stop
