1995 Chevy Truck leaking fluid
173,000 MILES • 6 CYL • 2WD • AUTOMATIC
MITCH & LISA
my 1995 chevy c-1500 p/u is leaking fluid at the rear of the trany where it attaches to the drive shaft.
would this be a repair i could do myself.
May 20, 2010 at 12:05 PM
  • 31,937 POSTS
Hi there,
This is a simple knock in seal, you will have to remove the tail shaft and pry out the old seal, to replace it. the seal should only be around $20 i expect.
Mark (mhpautos)
May 20, 2010 at 3:54 PM
