1995 Chevy Truck Help Me Please
215,000 MILES • V8 • 4WD • AUTOMATIC
HEATH587
I have a 1995 Chevrolet 1500 4X4 truck an it wouldnt start. i took the back line off of my fuel filter an turned my key on. it wasnt getting gas to it. i then dropped my fuel tank and replaced my fuel pump. i let the gas circulate for a few minutes an it cranked right up. i let it run for about 5 minutes an then i turned it off so i could put all of my tools up. that took about 10 minutes or so an i then got back in my truck so i could go to work an it would not crank again. its doing the same thing as it did before which is just turning over but not cranking. please help me out. thank you
Dec 2, 2008 at 8:25 AM
  • 110,248 POSTS
Hi:
Are you getting fuel at the fuel filter? If not, check the fuel pump relay and the fuel pump electrical connection to make sure it's clean and tight.
Let me know what you find.
Dec 10, 2008 at 2:35 AM
