1995 Chevy Truck egr valve
1995 CHEVROLET TRUCK
LUCKY323B
  • 5 POSTS
Engine Performance problem
1995 Chevy Truck 6 cyl Automatic 214000 miles
i have changed the throtle position sensor, o2 sensor, fuel filter. my truck wont idle good and when i go to drive it cuts out real bad until about 50 and when i go to go faster it will cut out. could it be the egr vavle?
Oct 7, 2009 at 3:13 AM
  • 110,244 POSTS
The EGR can have this type of affect. Remove it and check for carbon build up both in the EGR and the intake. If it is plugged, clean it out. Also, have you checked for vacuum leaks, fuel pressure, and has the check engine light come on?
Oct 7, 2009 at 2:40 PM
LUCKY323B
  • 5 POSTS
I am going to check the fuel pressure today. I have checked for vacum leaks. the check engine light will come on when i am going about 55 and it will act like it cuts out for awhile and then the check engine light comes and after a minute it will go off and run normal again
Oct 8, 2009 at 12:48 AM
  • 110,244 POSTS
Have you had the computer scanned?
Oct 8, 2009 at 2:08 AM
LUCKY323B
  • 5 POSTS
No I guess I will try that.
Oct 8, 2009 at 3:30 AM
  • 110,244 POSTS
Let me know what you find.
Oct 8, 2009 at 3:49 AM
LUCKY323B
  • 5 POSTS
it ended up just being the fuel pump. thanks
Oct 14, 2009 at 12:20 AM
  • 110,244 POSTS
I'm glad you found the problem. Let us know if you have questions in the future.
Oct 14, 2009 at 12:26 AM
