1995 Chevy Truck Diesel
224,000 MILES • V8 • 4WD • AUTOMATIC
PAUL DUKES
When I start the truck it`s quiet,it idles good. After it warms up it makes a rattling noise. It sounds like the vacuum pump,I was told it was the pump. I replaced the pump and after it warmed up it is making the noise again. It isn`t as loud as it was before I replaced it but the sound is back.What else could it be? It`s the 6.5 turbo diesel
Oct 24, 2009 at 8:54 AM
JCARLTON58
  • 12 POSTS
check crank pulley the rubber goes bad check the heat sheilds 1 over starter 1 on the other side of engine
Nov 30, 2009 at 11:50 AM
