1995 Chevy Truck brake light problems
254,000 MILES • V8 • 2WD • MANUAL
RUSSELLOHIOBOY66
hello, i have a 1995 chevy truck. my problem is i used the truck to pull a trailer last week and noticed the rear brake lights don't work, the third brake light on the cab works but not the rear lights. i changed out the brake light switch and no luck. i am leaning toward the turn signal switch but they are expensive and i want to make sure that is the problem. i am a mechanic and good with electrical but i don't have a schematic of the light system on my truck. i only have one power wire coming out of the brake light switch when the peddle is depressed. any help would be appriciated. thanks mike
russellohioboy@aol.com
Nov 30, 2009 at 12:24 PM
  • 75,988 POSTS
Check and test the turn/hazard switch
Nov 30, 2009 at 1:33 PM
