1995 Chevy Truck
TSINN14
Electrical problem
1995 Chevy Truck V8
1995 Chevy Silverado 1500 - won't start. Battery, starter, alternator all checked and fine. Only get 1 "click" noise when trying to turn key on. Where to go next??
Nov 22, 2009 at 11:55 AM
  • 75,988 POSTS
Double check the battery and connection if okay and starter is good its time to test the park/neutral switch and ignition switch
Nov 22, 2009 at 11:58 AM
TSINN14
[quote:56660217d1="rasmataz"]Double check the battery and connection if okay and starter is good its time to test the park/neutral switch and ignition switch[/quote:56660217d1]
Batt & conn are good. Will not start in park or neutral - does that mean park/neutral switch should be good??
Is there an easy way to test the ignition switch? That's a $130 gamble to buy and replace...
Thanks!
Nov 22, 2009 at 1:22 PM
  • 75,988 POSTS
Try the starter short out the battery terminal to the small wire on the solenoid and see if it engages the engine, if it does were back to the P/N switch and Ign switch.
Nov 22, 2009 at 1:28 PM
