[b:77b52a580b]Code 35 appeared, changed the IAC valve, will try again. Truck idles fast at times, should I also change the EGR valve & solonoid? Has anyone else had this problem as the code reappeared after changing the IAC. Thanks for any info... :D [/b:77b52a580b]
Nov 26, 2006 at 5:51 AM
