OK I HAD A BRAIN FART, WHEN REPLAING THE MODULE YOU REALLY WANT TO REPLACE THE COILS ALSO, IT IS REALLY EAY TO DO, JUST JACK THE RIGHT FRONT OF THE TRUCK UP LOOK INSIDE THE WHEEL WELL AND THERE IS A SMALL PIECE OF RUBBER, PULL THAT BACK AND YOU WILL FIND THE COILS, .5. MM SOCKET IF I REMEMBER RIGHT, AND THE MODULE IS BOLTED TO THE BOTTOM OF THE COILS, EVERY 2.2 I EVER DIAGNOSED WITH ONE OR THE OTHER I WILL REPLACE BOTH, SHOULD ONLY COST YOU 200 BUCKS TO DO IT YOURSELF, JUST LABEL YOUR WIRES SO YOU KNOW WHERE THEY GO BACK
JIM
Saturday, February 17th, 2007 AT 10:12 AM
