1994 Chevy Truck transmission
LANER42
Transmission problem
1994 Chevy Truck V8 Four Wheel Drive Automatic
I bought a truck and the transmission was rebult before I bought it. Today I started having blow back out of the fill tube what is wrong and is it fixable by Me
Jan 11, 2010 at 10:57 AM
PEAR69
  • 1,482 POSTS
If the transmission is shifting ok and running good, then the it is probably overfilled with fluid. Check the fluid level. If it is over filled, you can try draining some out by removing the dip stick tube and sucking some out that way...
Jan 11, 2010 at 5:15 PM
