1994 Chevy Truck tension pulley for assessory belt
QAZSWERT
MEMBER
1994 CHEVROLET TRUCK
V8
2WD
AUTOMATIC
230,000 MILES
Do they cedes-up? Can they be repair with a new bearing and do they come off with just the one bolt?
Thursday, January 14th, 2010 AT 3:01 PM
PEAR69
MECHANIC
They do seize up, and they are relatively easy to replace. They are replaced as a unit, and yes there is usually one or two bolts to remove.
If this pully is siezed (or begining to) then the idler pully is probably not far behind. While you have the belt off inspect the idler pully also.
