1994 Chevy Truck speedometer out trans wont shift
1994 CHEVROLET TRUCK
150,000 MILES • V8 • 2WD • MANUAL
WBMOSELEY3
sppedometer went out replaced vss did not help still shows no signal to computer for speedometer while connected to diag
any suggestions before replacing entire inst cluster?
May 6, 2010 at 3:51 AM
HMAC300
  • 48,601 POSTS
check to see if you have power coming to the speedo before you replace the cluster. you may have a wire problem instead.......
May 8, 2010 at 1:43 PM
