1994 Chevy Truck Rattling noise when accelerating and going
175,000 MILES • 6 CYL • 2WD • AUTOMATIC
MRMAG64
My truck is making a rattiling noise when you take off from a stop and when it changes into second gear, also it makes the noise when you go up a incline. There is no noise when the truck is at idle or after you get going. I recently had some transmission work done I don't think the transmission is the problem because the truck runs and changes gears fine.
Jan 13, 2008 at 11:33 AM
2CARPRO JACK
  • 11,533 POSTS
Check the starter bendix (gear) to be sure the spring isnt broken letting it fall back into the flexplate on acceleration and on inclines
Jan 14, 2008 at 9:44 AM
