1994 Chevy Truck oil pressure
114,500 MILES • V8 • 4WD • AUTOMATIC
STEVE ROBERTS
when idling,oil pressure drops to nothing when engine is warm. Oil pump?
Dec 10, 2007 at 9:57 AM
  • 31,937 POSTS
Hi there,
Have the oil pressure tested with a master gauge first, don't rely on the car gauge. If oil pressure is that low, you may have worn bearings, faulty oil pump, faulty pressure relief valve, worn cam bearings. You may be up for a re build, but get the true pressure readings first.
mark (mhpautos)
Dec 10, 2007 at 11:57 AM
